Husqvarna 2100 thread
Deets066
AKA Deetsey
5:26 PM
She sounds pretty lean. Good idea on not making another cut.
I had it fired before and piss revved it a lil bit but that was the first cut I made and got it good and warm. It needs a little more fuel on the low and a fuzz more on the high
smokey7
5:26 PM
Detroit
For sure! Its funny how a freash build can be garage tuned. Then u set it in some wood and wow its not even close. I dont remember it that was a fresh build or not but im sure you will have it spot on in short order.
Deets066
AKA Deetsey
5:26 PM
Shaun had it runnin and cuttin, but we use different fuel, possibly different ratios and different air filter
5:26 PM
Usually it's a task to drop start one of those things . About like rope starting a Harley .Although they say the thin ring version is a bit less taxing .
Deets066
AKA Deetsey
5:26 PM
This is the 395 piston version I believe. I'm pretty sure it's not a thin ring.
I drop start all my saws 090 and 088 too
Deets066
AKA Deetsey
5:26 PM
I drop start my 090 left handed.... With a 25" bar, not the 50"
Funny thing is I cant even drop start my 026 right handed and I am right handed
I think it's easier to drop start with a long bar. Just set the bar tip on a log
Brewz
7:26 AM
Hunter Valley - Australia
I plan to get some chains spun up for mine tomorrow.
I have converted my 30" bar from 404 to 3/8 and have a few 98 dl chains I see on my 066 that need 2 more links added to make them fit.
Also getting some of the 10* ripping chain joined up so I can get it milling
Brewz
7:26 AM
Yeah mate AM spikes.
I have the OEM inner spike but wanted duals.
That chain brake cover is off a 2101.
I took the one off my 2100 with a mostly working chain brake to preserve it and it doesnt have the outer spike holes drilled and I didnt want to drill it
flying pig
3:26 PM
Grande Prairie, Alberta
I picked up an outer spike for mine, it came in today so I'll see it tonight. Mine isn't drilled either. Dad said he never ran a brake because it was a nuisance. I guess by the time my uncle fell with it they had to have a brake so he put a brake on it. Dad said the mill wanted the wedge cut on the stump so the outside spike was a necessity. He also said he never ran a full wrap because he lost 2" to stumpage. I like that chain catcher, I'll build one on the lathe.
Deets066
AKA Deetsey
5:26 PM
I need to drill my outer cover. Is there an oem outer dog that matches? Or do ya just have to get AM?
Brewz
7:26 AM
The outer am dog did not match the OEM dog that was on the saw.
I just got the pair from the cheapchainsawparts guy on evilbay
Already had the holes for a chain catcher and the Stihl catcher fit nice once I spaced it over with a couple washers.
Will work better than nothing, I get nervous running a saw without one
