Husqvarna 2100 thread
thedude74
Bonafide & Stuff !!!
1:07 AM
Alaska
Finally getting around to swapping the 285 p&c for the 2100 top end. Cylinder was a rocky mountain chainsaw new old stock....made in Italy. Appears to be good quality. Dukes was out last summer so the piston was ordered from sawzilla.
thedude74
1:07 AM
Alaska
The end goal is to have a fun, fast saw to run a few times a year. Will run 3/8 and 8 or 9 pin.
For port #s I'm thinking 99* ex, 78* intake and maybe 125* on the transfers.
Do those sound decent?
Obviously going to mod the muffler, cut the base and chamber and maybe swap to a 288 intake and possibly a v-stack/uni setup....timing advance???
Suggestions would be appreciated.
Thank you.
hacskaroly
2100 Fanclub Member
1:07 AM
Northern Idaho, Ehh
I have this on mine, I didn't want to pay $100 for a crappy used OEM filter off of eBay that looks like it was used for scooping mud for the last 20 years. The unit was super easy to attach with the v-stack adapter.
farminkarman
I like the red & black ones
3:07 AM
Neenah Wisconsin
Thank you.
What piston do you have? How long of a bar do you want to run?
thedude74
1:07 AM
Alaska
It's a pro line window type piston. Thick ring type I believe. Plan on only running the top ring.
Unlikely I'll ever run more than a 36" on it...won't be milling with it either.
It will probably wear a 24"-32".
It's not going to be a regular use saw....just something to whip out and spank a 395 or 660. Lol....That's the goal anyway😁
thedude74
1:07 AM
Alaska
Right on. Yeah, some of that used oem stuff is outrageously priced. Where did you get the v-stack and adapter from?
farminkarman
3:07 AM
Neenah Wisconsin
I wouldn’t count on spanking a good ported 395 with your 2100. If you want it to be fast and don’t need to run a long bar, I would consider a 395 piston. It will allow you to widen the exhaust more. For numbers I would try 96, 116, 76. 98 exhaust is still good for long bar work.
Squareground3691
4:07 AM
New England
She cuts eh, 😆 maybe a little spank ,
