Squareground3691
- 12:45 PM
- May 1, 2021
- New England
I need ur future skills,Dang man! Save some for the rest of us.
I would be too, lol
I would be too, lol
Luckily mine still had it attached when I found it or else I would probably be trying to run it without it.Little did I know it was supposed have a rear brace to keep the carb from loosening up .
BUMPWould anyone have a set of thin rings available for 2100 no. 5016984-01 56mm
Thanks,
395xp piston swap?BUMP
Don’t you have to cut base a lot , for skirt length?, Not a direct swap no ?395xp piston swap?
You are correct, but it is an option if parts are not available.Don’t you have to cut base a lot , for skirt length?, Not a direct swap no ?
Are your skills available if I need them, ?You are correct, but it is an option if parts are not available.
We didn't have much for good options for quite a while. Now though, there's the Duke's 2100 piston that is an excellent direct replacement.You are correct, but it is an option if parts are not available.
Unfortunately it’s been out of stock, hopefully not for long,We didn't have much for good options for quite a while. Now though, there's the Duke's 2100 piston that is an excellent direct replacement.
It has been out of stock since last summer…Unfortunately it’s been out of stock, hopefully not for long,
It has been sold out for over 6 monthsNow though, there's the Duke's 2100 piston that is an excellent direct replacement.
@Duke ThieroffIt has been out of stock since last summer…
Perhaps it was in-stock somewhere in there and I missed it. The 395 piston definitely is a one-way street for a 2100…no going back
No, I have been watching for it, checking almost weekly. I ended up getting my 2100 piston from Lil' Red Barn off of eBay. I have not run the saw enough to see how it will perform, but the saw does fire up. When Duke's gets theres back in stock, I will be getting one of those too (maybe two of them now that I know @Stump Shot is hording themPerhaps it was in-stock somewhere in there and I missed it. The 395 piston definitely is a one-way street for a 2100…no going back
