Sty57
- 10:39 PM
- Jan 6, 2016
- Land of Cheese & Beer
Yes it's just two a post.You only have a switch with two stick, right?
Means, on/off only
I had to think a bit when I saw the old wiring drawings from JRed 2156/2159, and how it is compared to my 372's.I do have another genorator with one lead. There was two different saws in the box of parts I got. Maybe I'm using the wrong one.
One was a 2172 and the other was a 2163.![]()
Thanks Tor, that diagram is what I was looking for.I had to think a bit when I saw the old wiring drawings from JRed 2156/2159, and how it is compared to my 372's.
All my 362 and 372's has one wire generator, but the switch has two choices, so I can't verify 100% how the two wire system work on your 372......but, if it's the same as they had on 2156 your female wire goes to the carb heat elements (they are serie wired), while the other wire go to the switch and in serie wiring as always
Give me 10 min and I will upload the sweedish WS for the wiring
The 372 switch my 372's has:
Page 19 in the sweedish WS for 2156, etc
just currious, do those two generators has the same resistance?
thanks for checking it on 385 and your find is very interesting, I fear it count for many 3xx serie saws.I was digging through my parts box last night.
I have one 385XPG case and an 385xp case. The XP case is NOT drilled and tapped for the generator.
I have never seen a different part number for a XPG case.
alternative PTo bearing.Tor wasn't the 242 the one you where trying to find an alternative seals for?
Did you ever come up with one?
that sucks, but they had drilled the holes for those two generator screws?I am working on converting a 550xp to xpg and while the generator holes are on the xp chasis they were not tapped. Just smooth holes. So i guess husky had some that went an extra step of tapping for g models and xp models skipped on down the line
awesome! I'll check and setup my 550xpg and give you wiring system.Yes they were drilled so it was no problem gettng them ready for screws. I have the generator installed and flywheel on.
I had a 545 case that the holes stripped due to being to shallow. I am glad you got yours fixed.awesome! I'll check and setup my 550xpg and give you wiring system.
I sized up my 550xpg case, thread holes are 16mm deep but threads are only 9mm deep.
If I had to drill I wouldnt go deeper then 16mm, not much meat left
I am not sure when 394XPG came, but according their IPL's it wasnt before 1995, first years it doesnt look like they had xpg at all92 394......no holes [emoji53]
