Spike60
- 2:20 PM
- Feb 8, 2016
- Ulster County, NY
Got ya. Is all the linkage for the Throttle and choke different to?
Use the same choke lever and throttle link from the 630. All of these links "work", but a 272 link is slightly longer and results in a crazy high idle. These saws already spin up pretty quick on high idle as it is, but the 272 link is like 3/4 throttle or more. Scary!
One other item on sticking with the 630 carb is that you will still have a fast idle. 272 carb will not have one at all on a Jonsered. Reason is all Jonnys in this family had the fast idle set with the choke lever, and all Huskys had it set with the thumb latch on the fuel tank. So, only the Jonsered carbs had the fast idle cam that can be set with the choke lever.
Edit: The insane fast idle problem is not really an issue on the Jonnys, due to the choke lever idle set. I was thinking of a 61 to 272 build that I recently did, and that is where you want to be careful mixing up the throttle links.
