two4spooky
- 11:04 PM
- Dec 22, 2017
- Southeast
If you can get the Pac-Man to remove the jets, you can grind a slight flat spot on one side and it will fit. Or at least mine didHey Shaun, if you can remember, slip a piece of tubing in when you send the PM700 cylinder back. I bought a new Husqvarna BV125 and it has the larger spline screws. I found I could move them with the large PacMan tool but it takes a lot of effort.
Mark
Where I'm at. Waiting for advice or opinionsOkay, while we are here: muffler is off, WCS deflector(1 1/8"x 2 1/8" size) in hand to mount in front(directly in front, same side) of the stock exit. Leaving the internal muffler parts.
#1) What size to drill for the WCS port: Two 1/4" holes? Two 3/8"? or what? and #2) What about the factory 90* piece in/below the medieval castle turret toothed OEM deflector? Bend it, cut off or leave as-is? Milling, torque and heat reduction is the goal. Low(9-10k) RPM torque not screaming RPM cant monster kind of saw. Milling hardwood with a 36" bar
I would open up a hole the size of the inside of the deflectorWhere I'm at. Waiting for advice or opinionsView attachment 450454View attachment 450455
Final results:View attachment 450603
Both spark screens in place. Just looking for longevity, cooling and torque for milling. Looks okay to me. Opinions welcome and thanks to those who add
I think more power = more heat, but I've never verified stock vs ported cyl & muff temps. Just mill in cool weather.View attachment 450603
Beautifully done!View attachment 450603
Much appreciation. Yeah, my little free time today for side hobbies and interest usually comes late in the evening after work and after daily responsibilities are met. And yes, too often after enjoying a few drinks. I'm sure it is obvious. Pardon my recent, sideways and often rambling post. Just a carry-over of a hobby and previous employment from my younger days. Thanks for understanding. Many thanksThat’ll do pig, that’ll do
