Husky 346 OE to NE Intake conversion
Agrarian
8:18 AM
New Hampshire
I have a 346OE whose skins are pretty rough and a 350NE (with primer bulb) that is in great shape cosmetically. I want to take the 350 top cover, rear handle and primer stuff and wrap it around the mechanicals of the 346 OE. Is this possible? The parts look like they should fit.
I have to believe this has been done many times by people here if it is possible. I did a search but didn't turn up anything.
Any info is greatly appreciated.
Onan18
OPE Sponsor
8:18 AM
Georgia
Isn't the 350 top cover secured by screws as opposed to the quick straps found on the 346? If that's the case, I don't know if that would be an issue or not.. But that's the first thing that comes to my mind with that question.
Good call, 346 has straps, 350 screws.
Tor R
Novice
2:18 PM
Mandal
350 top cover doesnt fit on 336 as stated over me.
350 Fuel thank fit, the same with start cover and clutch cover.
Are you planning to build a 3xx fleet now?
Agrarian
8:18 AM
New Hampshire
I wanted to see what all this hype was about for the 346 and just working with what I've got. I've got a 359 carcass too that I might do something with.
Agrarian
8:18 AM
New Hampshire
Ok, if I buy just a 346 NE cover, will it accept the primer bulb assembly etc that I want to steal from the 350 and will it fit on the 346 OE crankcase?
psuiewalsh
Basement Bodging
8:18 AM
Nottingham,pa
If you do not care about the primer setup you can plug the carb port and the port that returns fuel to the tank on the NE carb. I think the casting on the oe where the primer bracket screws to is missing the boss to mount it.
Agrarian
8:18 AM
New Hampshire
I'll have to check that - it would be a deal breaker I guess.
ft. churchill
5:18 AM
Along the '49 trail in Nevada
I own a 346ne and I just did a porting job on a late model 350. I was suprised at how much looks like it will change from one saw to the other.
idiotwithasaw
7:18 AM
Ky
Pretty much the only thing different is the case and top cover. If you want your can take your 346 top end and put it in your better looking 350 case. I actually prefer it that way, I think it's lighter.
SawTroll
Information collector
2:18 PM
Troms, North Norway
It likely would be simpler to swap the carb assembly (including purge assembly) as well between the two saws. The carbs are basically the same, any difference has to do with age and not model (as far as I know).
Tor R
Novice
2:18 PM
Mandal
If I remember correct OE doesnt have mounting bracket for purge assembly, it look like an ear compared to OE.
You have to make the mounting bracket and find a way to attach it on OE
Tor R
Novice
2:18 PM
Mandal
pictures say more then words....
OE:
NE:
If you don't have this ear for the purge attachment you have to make one if you want to use NE topcover and purge.
Onan18
OPE Sponsor
8:18 AM
Georgia
I think the purge mounts in the (filter holder) on a 350 and "floats". (I.e. not attached to crankcase).
Joe
idiotwithasaw
7:18 AM
Ky
Just block off the primer port on the carb and go on. It's one less thing to worry about.
RIDE-RED 350r
8:18 AM
Blossvale NY
I have a question/theory on the purge bulbs: Seems as though in my limited experience anyway, that the only saws that have purge bulbs are the saws equipped with Zama carbs. If this is true, I wonder what the deal is as to why a Walbro can draw fuel without a purge bulb and a Zama cannot??
However I would add: When I was trying to narrow down a stubborn tuning issue with an OE 346 I overhauled a little while back, I swapped in the Zama out of my personal NE 346 and just capped the purge line fitting on the carb. Saw started and ran just fine. And after figuring out that the accelerator pump in the Walbro was bad, I replaced it with the current Zama replacement for that saw...without a purge bulb.
So what's the big idea on this?? Why did Husky think they needed a purge bulb on these saws to begin with??
