Husky 2100 - stripped hole, repair issue
1:42 AM
Jeez, that’s a headache. Annoying to weld as well as it’s near and edge and will be hard to get perfectly clean.
They often cast in thicker metal where screw holes will go. You’re getting really close to the edge there, I’d be careful not to tighten your insert up and crack the tank. A good application for Loctite.
The fact that it goes into the oil tank shouldn’t matter much. Many Husky’s have screws that enter the tank.
BuffaloBill
12:42 AM
Wisconsin
I agree with dr, about since it’s only the oil tank on the backside of this area, the risk of a leak isn’t bad at all. In fact maybe I would purposely drill through into the oil tank, to allow the insert to be greater in length, with that much more thread engagement. More threads for loctite to bond to and allows use of a standard tap.
And on the welding topic, I’m no certified welder and have zero experience welding magnesium. But have TIG welded aluminum since 1991. That’s probably a high quality cast part.(?). But if a cast part, it’s still apt to hold impurities that come out of the material in to the weld pool, trying to mess up your work. It helps cook out the years of oil absorbed in pores and cracks, by performing a bake out in an oven, and cleaning beforehand and afterwards with acetone. Do that a few times until after the previous bake out, there’s no longer any visual evidence of oil coming out. Like is done before powdercoating. Then weld it.
But to avoid all that work and risk of still ending up with an imperfect weld, I’d vote for the insert route.
srcarr52
1:42 AM
Iowa City
Those tank halfs are glued together. Chances are with the heat you'll need to fill in that hole you'll burn the glue out of the seam causing an oil leak. It's probably best just finding a used tank.
hacskaroly
2100 Fanclub Member
10:42 PM
Northern Idaho, Ehh
I like this idea, makes sense probably the route I am most likely headed at this point. As for welding, I took a college class in the mid 90s on welding and had a great time with it, except for the time I was TIG welding with a hole in my glove and picked up a hot piece of metal...I want to get back into it, just need to get a welder first.
Good to know about the halves glued together, looks to be welded, but with the paint on top it was just a guess. Unfortunately this is my second tank (eBay), the first one it came with had a broken rear handle, looks like someone dropped it rear end down or dropped something heavy on it. At this point, no harm in attempting a full through insert like @BuffaloBill suggests. If it works, great, if not oh well, its a learning experience and I can part out all of the little pieces off of the tank and sell them for $$$ on eBay...:D
I truly appreciate everyone's input and comments I have learned quite a bit from all this!!
WI_Hedgehog
12:42 AM
Milwaukee, Wisconsin, U.S.A.
There is possibly another option (mind you I'm not an expert on the subject):
Grind out any cracks and rough edges in the existing holes (they lead to stress fractures). Make everything have rounded surfaces.
Metal-epoxy the tank closed, then use a tank sealer coating like discussed in other threads.
Beat a metal fender washer (on a wood block with a hammer) to conform to the curve of the frame.
Super-glue a nut to a metal fender washer (just to hold the two together), then stack a somewhat flexible plastic washer on that (but not permanently adhere it). Use a hand grinder to thin the nut enough so the nut/metal_washer/plastic_washer stack fits in the opening. (the stack will heat up while grinding so you don't want the plastic washer on the stack while grinding).
Slide the stack in with a needle-nose pliers and bolt the handle on.
The plastic washer will absorb some of the deformation between the metal washer and the metal frame and also absorb some shock. The washers in combination will spread the load over a larger area, reducing stress over-all, hopefully avoiding a future metal failure.
Yukon Stihl
10:42 PM
Great White North
You could fish a bolt in through the tank and use a nut to hold the handle to the bolt,like a bar stud.
If all else fails,glue the bolt in with "The Right Stuff" to keep it from leaking.
1:42 AM
Probably easier to tap for a short stud. Add sealant. Then just flex the bar over it. At least if the nut comes loose it won’t be in the tank.
hacskaroly
2100 Fanclub Member
10:42 PM
Northern Idaho, Ehh
Good news, @BuffaloBill offered to help me out with this fix. I sent him the tank and he was able to clean up the threads on the hole, create a custom insert, get it lined up and sealed in!
Custom jig to ensure straight threading!
Custom replacement insert. Since the original repair offset the hole, Bill had to use math and micrometers to make sure the new bar screw hole was in the right spot!
The final result was the new plug sealed in place with the handle bar hole lined up perfectly! I am VERY happy with how it turned out, Bill did a great job with this (Big thanks to @BuffaloBill)! If it was up to me to fix, I would still be sweating it out trying to figure out how I would do this without proper tools... :D
I ordered a felling dog with the AV mount and it arrived while the tank was out. I matched it up to my old tank and it fit fine, however when the repaired tank arrived back, I found that the AV mount did not fit it and then realized the one difference between the two tanks, one has a flat face at the front handle mount and the other has a lip.
Old tank on the left with the flat face and the newer tank on the right with the lip. For those who know 2100s, did they make one type up until a certain year and change or is maybe the right on a 2101 tank? Like I said, except for that lip, the rest of the tank is identical.
As shown with the green arrow below, the AV mount hits the lip. Do you think there would be an issue using a Dremmel to notch out a slot for the AV mount to fit or is there possibly a different mount style for this style tank?
Chainmale
5:42 PM
Tasman New Zealand
Wow. Nice work @BuffaloBill
I wonder if the one with the lip is for the rubber front av mount, and the other ones for the spring one?
srcarr52
1:42 AM
Iowa City
Awesome work!
You can grind that whole lip off if you'd like. This bracket was mounted below on 1/2 wrap saws with an aluminum spacer between that fit into the groove on the handle.
hacskaroly
2100 Fanclub Member
10:42 PM
Northern Idaho, Ehh
I have the aluminum spacer, luckily it came with the handle I bought. Looking through IPLs, I wonder if the tank is instead a 298 tank as the IPL shows it with the lip.
But then again now that I look at this, there isn't a manual oiler in this image, so many close variations. Either way, looks like I will be knocking off that lip.
BuffaloBill
12:42 AM
Wisconsin
Thanks, I was happy to do so. I have to admit that from the original pictures, I didn’t realize that there was an internal structure complicating the drilling/tapping operation.
The shape of the tank made it impractical to fixture on the mill, or so I thought anyway. But since there was the second non-damaged threaded hole, I used that to attach the quick hack of a drill/tap guide. I first drilled a 7/16” hole through the fixture, and ran an end mill of same size in a cordless drill, to enlarge and straighten out the bore in the tank. In that situation an endmill will try to screw itself deep in the hole, so chucked the endmill deep in the cordless chuck to prevent making the hole too deep, etc.
Then removed and re-chucked the guide in the lathe, opening it up to 1/2” so the tap would pass through. I made the insert from a chunk of 1/2-20 threaded rod. My bottle of Loctite 271 is quite old. I’m hoping it still bonds well!
The resulting tapped hole has deep threads on one side but only 1/8” or so depth on the other. The insert seemed to tighten up well against the bottom of threads, so am hoping that and the Loctite will keep it in place. The insert stood proud of the tank surface by about .025”, so I used the guide with a cordless drill-chucked 1/2” end mill to take it down flush.
