How to square file
Wolverine
dilligaf
5:51 PM
This is the bar. I laid this on the anvil of my bench vice and whacked the snot out of it. Enough it probably should have broke off a rail. I didn't even budge it, anywhere.
I'd have to remeasure. I did back when I tried but can't remember. It's a 63 bar and the chain wiggles a lot.
Wolverine
dilligaf
5:51 PM
My old bearing bar rail closer will close the rails too much, but that's on 50. Never tried it on 58 or 63.
This type?
thumbnail.asp
Skeans1
2:51 PM
I make a lot of replacement parts for Silvey round, swing arm, RSII grinders. I haven't gotten into making anything for the Prosharp and SDM4.
At least on the pro sharp there’s only two wear items I’ve found on mine one would be a real easy to build a bushing for cable, the other is the cable itself can stretch after x amount of time in the 30 years we’ve had this one it’s had two cables from stretch.
5:51 PM
That’s surprising, the paint is even still mostly intact on the bar
kfd518
4:51 PM
Central Texas
That was before being V’d and beat.
Rails aren’t cracked already from all the beating? If cracked they’ll spring right back until they just break off. If overly wide I have had them feel like they aren’t closing at all but we’re SLOWLY closing. If depth is getting a bit on the shallow side there is not as much leverage to get them to bend back in.
5:51 PM
Looks like somting ate your tie strap! lol
concretegrazer
4:51 PM
Mo
Angle grinder??
Hacksaw??
Hoof rasp?
Which one is c? I always pick c.
You are cutting White Pine and meant to?
Hackberry. But that's about all its good for now.
How.. with a file or a stone. What do I win? o_O
Stone it is. How about some dull files?
Seriously though I never thought I'd be able to stone a beak into one before it had issues in the cut.
Wolverine
dilligaf
5:51 PM
No. I used a hacksaw blade in the groove when I had the hammer in my hands. Depth is not an issue, there is plenty. My son is going to trade school for welding so some day I may have him weld it and regroove. Hate to pitch it.
