How to square file
11:50 PM
The roller bearing slide works better on the RS 2. I never could get consistent chains on mi e with wore out stuff. I prefer a swing arm in the lower end. Never got to use a Pro sharp and probably never will at this rate. The Simington is the only one with parts availability now so it’s better than a used Silvey swing arm
Skeans1
8:50 PM
Silvey parts only have one place you can get them and they’re still available. Dave if you ever get out here you’re welcome to try my pro sharp.
Skeans1
8:50 PM
I thought the best grinders were swing arms?
Prosharp?
Swing arm style is the base model with the least amount of adjustments, take a the upper models the adjustments are fast easy to make without lasting design changes.
Leeroy
11:50 PM
Harmony,RI
Anyone putting out really good chains from a RS2?
Negative here. I just dug it out of the barn while looking for some rusty files lol.
I bought it from Baileys along time ago. They still carried 3 models of Silvey, the RS 2 being the least expensive. Baileys shipped it without a stand and never did send one. I set it up on a bench. There was a learning curve with dressing the stone, best stones etc. There was some play in the chain. I think I corrected it by pulling down on the chain, or pulling it against the stop.
I do remember getting a few chains almost scary fast in black and red oak.
But to me, it's not worth the effort and time. Made a dusty mess in the basement, and was no faster than filing. I get more consistent chains filing.
I use different ,sometimes funky angles on different wood and change them through out the season, job, etc. Almost set it up a couple years ago, as I was in a bit of a filing slump. Could get them to cut, but not CUT. Pair of reading glasses put me back in the saddle.
kfd518
10:50 PM
Central Texas
a small wedge in the bottom of the bar between the chain to tighten it up helps a lot.
I guess what I’m meaning is that I have some play in some of my bar grooves and the chain pushes sideways quite a bit. Are you referring to wedge in bottom side of bar between bar and chain or somehow between groove and chain driver?
I know I either need to get a bar closer or make a shim so I can reset the groove width.
Wish I could find the old Oregon style closer that you changed shims on and hammered it down the length of the groove.
11:50 PM
In the bottom. Just to tighten the chain up
srcarr52
11:50 PM
Iowa City
I make a lot of replacement parts for Silvey round, swing arm, RSII grinders. I haven't gotten into making anything for the Prosharp and SDM4.
Wolverine
dilligaf
11:50 PM
I’m not so sure about that rail closer tool. Kris made a bearing type that I tried on a 36” Windsor bar that has V’d grooves. No dice. I put it in a vice to try to pinch them back together, no dice. I beat the snot out of those rails and I can’t get them to close even a little bit.
kfd518
10:50 PM
Central Texas
How much to wide are they? How deep is the groove still?
