How to square file
Sierrawoodsman
12:00 PM
Dayton Nevada
Bump
Very nice work!
12:00 PM
I haven't touched the rakers yet.
Don't. You'll realize that as that cutter gets dull, and you square it up better, it'll get more aggressive. .020" rakers with a square chain is a beautiful thing. .030 with square in hardwood sucks.
12:00 PM
I'll be cutting hardwood mostly so appreciate the heads up. This square filing thing is not an easy task.
Converting from round to square takes time. I've only been doing it for a year and a half, and it gets easier every time. You'll be able to touch up a 20" chain in 10 minutes if you keep at it. And a chain vise will speed you up and increase accuracy
12:00 PM
Round to square...
15 minutes or so..
They get a little warm..
Especially when the chains are this nasty.
It's all fun and games til someone gets their eye poked out.
Good lord that's sharp......and so repeatable
Hedgerow
11:00 AM
I even put a little beak on there for real life action..
Looks good...Is that with the salmon colored wheel that comes on grinder?
Yep. I'll get all the good I can out of it.
Can you slosh them around in a metal can with some kind of solvent?
I've tried air, brake cleaner, carb cleaner. without good enough results to bother with.
So I just grind em dirty. Then re- dress or spray the wheel off when it stops grinding and starts rubbin'..
12:00 PM
You'd think those would take oil off. I bet it's burned wood residue. The brown stuff you notice about 10 minutes after your oiler hole gets plugged.
