How to square file
Brush Ape
Direct Connection
6:45 AM
Metropolis, Il
Getting the 404 squared up. Not much side plate yet. Going to try it like this if I've got something that will pull it.
Jesus H. Martini....
racerjohnbf
7:45 AM
VA
I like how you mounted it to the vise. I also like the thumb wheels in place of the wing nuts.
Thanks. I wanted the Stihl bench mount version but wasn't willing to pay the asking price for one of those. The thumb wheels do make changing angles much easier, they came from mcmaster also.
paragonbuilder
7:45 AM
Norwich, CT
I've got one. But I don't think the angles will adjust that much. I need to look closer at it.
Magic_Man
Oh Yea !
7:45 AM
SE Ohio
I also removed the spring from the depth adjuster and put a jam nut there. Stays locked in place better and you can use the flats and points as reference for adjustment.
racerjohnbf
7:45 AM
VA
Just a little update, I checked my file roll angle and it is set to 10°. I will add that in my opinion, while somewhat tedious, it is worth it to reset file roll so you can file into the tooth on each side of the chain.
X 66 stang347 X
7:45 AM
Georgia
I found this square grind wheel going through my wheels so I'm going to try it out. I know a little about doing it so I'll come back with my results.
big t double
You can call me Teddy Eastwood.....
6:45 AM
do you have the square grinding attachment for the usg? or are you fitting that on another grinder. I have several of those wheels, just waiting to score the attachment. needle in a haystack.
