How to square file
Homemade
2:14 AM
Wisconsin
I went thru all this too, it drove me mad, I took the Simmington cure.
I’ll second that. I also like that in the “how to square file” thread, the best advice is to buy a grinder
Wolverine
dilligaf
2:14 AM
Woodpecker
Sassy Madam
2:14 AM
I think having the grinder will make you a better filer. You can see what it’s supposed to look like
I'll second this. I got way betterer at square filing while in the field after I got the simington.
Federico
8:14 AM
Italiana
[QUOTE = "Swizzler, post: 1246570, member: 16479"] Il mio primo dente
[ALLEGARE=completo]296208[/ALLEGARE][/CITAZIONE]
Skeans1
11:14 PM
And after filing on a bunch of teeth til there was almost nothing left I tried to make a "race" tooth . .
View attachment 296209View attachment 296210
You’re pretty low on the corner with quite a beak for a work chain can it work for a bit yes, just as long as one that the corner is matched to the outside corner.
2:14 AM
Put it in some wood. Compare it against some of your round file chain. See what you think...
Time the cuts. Then tweak the cutters and rakers as you see fit.
Then report back. Lol.
8:14 AM
Huh!
Filing a whole EXL loop away into nothing for practice?
Blasphemy! :eek:
8:14 AM
Seemed like the best use of the 28" full-comp chain I ordered by accident. :)
So You are practicing to square file without being able to try the results, or do You have a suitable bar but don't like full comp? o_O
