How to square file
Toad22t
9:34 AM
Central Wisconsin
For that gearing, I'd use bout this much.
Keep the rakers less than .025 till you can test it for load.
This cutter measures .019.
You gonna be running in 10x10?
Or 12x12 up at Scott's?
DAT der is a purdy toof.
I'm planning on running up at Scotts. That's the plan so far. Are you and Alan going to make it? Last time I talked to him he wasn't sure if you guys are going else where or Scott's.
RI Chevy
10:34 AM
earth
Looks real nice!
Dolmar Junkie
Not interested in rehab, just more Saws...
9:34 AM
N.Central Arkansas
I drill a hole in a golf ball, makes a great file handle.
I do the same thing except I add a nut inside to keep from wallowing out the hole(drill the hole slightly smaller than you could push in buy hand and squeeze in with vise.) Trick I learned from my Grandpappy in the 70's that and the same setup with a piece of wood for a T handle.
I have them on everything from tiny files up to hoof rasp'...
