Nutball
- 3:43 PM
- Oct 31, 2018
- Mt. Juliet, TN
Should not be possible, steel need to reach critical temp of 800 or more celcius (1500? farenheit) to harden when quenched, wich is a rapid cooling.
When steel turnes blueish around 500 F that is whats called tempering wich lowers the hardness.
When you "rock" a chain that could harden it some, I think it's called deformation hardening or work hardening when it's not favorable.
I was helping a friend with some chain sharpening and stuff, and had to regrind all of his chains very slow and carefully to de-harden them, because he had always ever used a grinder, and they could not be filed in the woods. The grinder will turn the teeth blue, which is a good indication that they have gotten hot enough to harden. I know the color change is also an indication you have lost the hardening. I'd say color change doesn't mean hard or not, it indicates a possible change in hardness. What matters is how fast it cools when hot. The fact that sparks are made when a grinder is used indicates steel is reaching red hot temps even on a microscopic surface thickness on the tooth, then the rest of the tooth quickly cools that superheated skin.
