How much more hinge wood for dead trees?
davidwyby
Rural desert logging
6:00 PM
Extreme Southeast CA
It's common practice around here to make a small plunge cut 3" below the back cut and stick a wedge in it ,basically turning a small chuck of the tree into your wedge.
You can also do a V plunge which allows you to insert 2 wedges in the sides before the back strap is cut.
I don’t get it. Pitcher?
Catbuster
Roadbuilder Extraordinaire
9:00 PM
Gateway to the South
That’s interesting, I like it. It looks like it gets a wedge in earlier that you would starting a back cut and putting one in sideways on a small tree while not closing up the kerf as much as you’d think.
Maintenance Chief
9:00 PM
South Carolina
It's a handy little trick. You can keep cutting under other wedges too, but it's just in more resilient wood that holds better than dead.
You definitely won't cut your wedge.
