Wood Chopper
So so sleepy....
- 3:16 AM
- Apr 26, 2017
- Mechanicville NY
All 3 of those are clones? Are they all built the same with all the same parts? Did you have and bad parts from the kits. What topends are you running on them?
Hey Smokey. The 660 with Stihl bar has the cross top end base gasket delete and oem intake boot an pulse lines. Everything else was from the kit. I did use hwy gaskets and seals
The other one is hwy big bore and runs way better than I thought it would
440 kit I must have got lucky from what I’ve heard. I had the base milled To get acceptable squish at .19 everything else the kit parts. Hwy seals and gaskets
Runs great.
