How are the Asian 660s holding up???
Wood Chopper
So so sleepy....
7:02 PM
Mechanicville NY
All 3 of those are clones? Are they all built the same with all the same parts? Did you have and bad parts from the kits. What topends are you running on them?
Hey Smokey. The 660 with Stihl bar has the cross top end base gasket delete and oem intake boot an pulse lines. Everything else was from the kit. I did use hwy gaskets and seals
The other one is hwy big bore and runs way better than I thought it would
440 kit I must have got lucky from what I’ve heard. I had the base milled To get acceptable squish at .19 everything else the kit parts. Hwy seals and gaskets
Runs great.
Wood Chopper
So so sleepy....
7:02 PM
Mechanicville NY
. Big bore with the 28”. Was hungry today.
Wood Chopper
So so sleepy....
7:02 PM
Mechanicville NY
I think the big bore is a bit stronger but I’m running 2 different bar set ups. I’m running a 24”. On the cross and a 28” skip on the BB.
I took one vid this morning of the cross with a somewhat sharp chain. I’ll try to upload it
7:02 PM
Nice 660 there! Nothing wrong with that. But you gotta get it ported! Lol
Wood Chopper
So so sleepy....
7:02 PM
Mechanicville NY
Lol. With the cross it technically is. I’m sure I can have someone get a lot more out of it for what it is I think it’s fantastic. I would put it against a stock 660 any day Until something comes apart inside anyway [emoji51]
Wood Chopper
So so sleepy....
7:02 PM
Mechanicville NY
Just gotta say that's one sweet ass jig you got holding the log in place!
It is heaven. Don’t get to use them often but when I do it sooo easy. Cut the tops off make a pile for the chipper then buck it up off the ground waist high. Chains stay sharp much longer. [emoji51]
T.Roller
7:02 PM
Southeast, TN
The one thing that I didn’t go oem on and will swap out this winter is the wrist pin bearings on all 3 saws.
I'm running the AM on mine. Pulled it down to switch the numbers up a bit and while I was in there checked the bearing. Looked good so far.
Wood Chopper
So so sleepy....
7:02 PM
Mechanicville NY
That’s good to hear. I guess I’ll take a peek soon.
