JimBear
9:31 AM
IA
Or at least I figure you are referring to Country Stampede...
ATTACH=full]187083[/ATTACH]
Workshop
9:31 AM
Nixa, Mo.
Hmm, checking Craigslist and Marketplace down here rough sawn oak is 1.00-2.00 a board foot.
For that price I can go ahead and use pressure treated lumber.
I was wanting to use it for new flooring in the trailer I just picked up.
Unless I'm figuring it wrong. Which would not be unusual.
Workshop
9:31 AM
Nixa, Mo.
I think I did figure wrong.
1x6x8 foot at 1.00 per board foot would be $4.00. Correct?
Hinerman
9:31 AM
NE OK
If you go with pressure treated find a lumber supply that still carries CCA treated lumber, as opposed to the ACQ treated lumber. You won't find CCA at Lowe's or HD.
67L36Driver
9:31 AM
By spraying carb cleaner at the recoil while running I found the vacuum leak. [emoji37]
moparnut88
10:31 AM
US
Is it pricey?
It can be last we got was from the local havco trailer flooring plant. The apitong comes from Asia I believe it's about as strong as oak but way lighter normal life in the weather is 7-15yrs. Most of the commercial heavy trailers from manac flat beds to trail king detach trailers have apitong from the factory.
