moparnut88
5:18 PM
US
Sounds like you guys did well! We r just getting back home from a local demo derby. It was great to get to see the cars with $10k engines not when for a change. The local boys took everything home! They put on an amazing show though!
4:18 PM
Logger's class is:
Any work saw.
20" bar or greater.
Stock muffler.
Air filter.
Round ground chain only.
Sounds like my kind of class.
Aka:
Tree monkeyed 064 wins Thomas some money's...
Beaten only by a good running ported 395.
He did well..
Ported 395s are scary!
teacherman
4:18 PM
NW Virginia
Good morning!
Tomorrow I go pull the forms off the sidewalk section I poured. That Menard's concrete would not hold water- it was dry despite having excess water mixed in. The result was that when it came time to work the cream into a smooth surface at the end, it was all gone and a sandy color. I expect it to erode off and be rough and crappy fairly quickly, and I do NOT want to repeat this process due to bad crete. Grrr
teacherman
4:18 PM
NW Virginia
Maybe a bit of portland mixed with some form of bonding chemical could be applied as a skim to prevent the erosion... any htoughts?
Hinerman
4:18 PM
NE OK
The 4 cube was a comedy of errors..
Thomas can tell you all about it..
Other classes went well.
Comedy of errors is correct. I missed my upcut, game over. Matt's brake engaged on his down cut when he hit the wood, game over. We both have saws to go 1 & 2 in this class with good runs.
Matt used my 4 cube saw in the alcohol class, and the time was fast enough to win the 4 cube "gas" class. Yep, I choked. :mad:
