Douglas Ostrander
3:31 AM
Waukee Iowa next to I80
Don't know if I can get a 10 or 12 rim yet! I think there is a knob to adjust the speed or something on the saw control. The drawings don't say what the cartridge is. Or just keep it out of high flow.
awol
3:31 AM
Cabool, MO.
No, I mean the raker to cutter height difference.
As the length increases between raker and cutter, the height differential between the raker and cutter must increase incrementally to retain the "angle of engagement ".
AKA "progressive raker setting" Basically, the farther back the cutter us filed, the more clearance you give the depth gauges.
Workshop
3:31 AM
Nixa, Mo.
So the Stihl dual file would take care of both, right?
Workshop
3:31 AM
Nixa, Mo.
Been busy building things for around the house. (honeydoos). This time I'm going to build something truly useful.
A gun cabinet. But no glass front. I want a place to store them, not a place to advertise them.
Workshop
3:31 AM
Nixa, Mo.
I give my rakers the 4 dings treatment.
4 dings with an angle grinder.
Works for me, but then, that's just me.
Hedgerow
3:31 AM
Now I think I know why my long chains won't self feed and make a lot of dust without dogging in. I need to lower my rakers more than normal (.025), since my cutters are getting small (less than 25% life left in cutter). Correct?
Correct, when they're back past the rivet .045 is not uncommon for a work chain.
67L36Driver
3:31 AM
Good question. I dont know. Dont know if I would want to hold a counter on there while it is running.
Its a big sproket.
Sent from my SM-N910R4 using Tapatalk
As an aside:
That 'QD' taper lock bushing opens up several possibilities for roller chain sprockets or 'V' belt pulleys.[emoji848]
Just so you know.[emoji6]
Hinerman
3:31 AM
NE OK
"Above all," stands the orange and white, the standard by which all others are measured. Kind of like Harley-Davidson...
Finally, somebody is making some sense around here. Teacherman in 2020...
