- 7:59 AM
- Jan 3, 2016
- West of Kansas City
Evening guys.
That's a red husky 350 right?Any Jonsered guys close to Wichita? There's a Turbo 2050 at AOK Pawn on Broadway marked 129. Its been there for a while and they're taking 30% the saws like that. Its definitely been used but it looks taken care of. I haven't inspected it close though.
You would be correct.2150 is the 350
Is that a Craftsman? Or Roper branded?
My understanding is that Roper put out some under the Roper name the last few years they made saws. After Sears quit buying from them.
Sure is clean. I wonder how much it will go for?
GoodSorry I'm way behindhow're you guys doin?
I had issues with my Zip carb at first and then I broke down and bought a $16 complete carb kit. And fixed!Fixed a 300 homelite for
The pawn shop need to run it in some
Wood to make sure it's all working well.
Need to go back inside my 2159
Somethings not quite right. The
Zip I was working on has carb issues
Again
The plastic nipple on the bottom of theI had issues with my Zip carb at first and then I broke down and bought ua $16 complete carb kit. And fixed!
I have a carb if you can't get it fixed, but it will probably need a kit also.
Yeah that last kit I bought for a Tillotson had a cork gasket for the inlet, I like it better than the black one, It's thicker, but the black one in my Zip hasn't leaked yet. Yours might be cracked.The plastic nipple on the bottom of the
Carb is leaking, I think it needs a new one
The round plastic part is warped and unevenYeah that last kit I bought for a Tillotson had a cork gasket for the inlet, I like it better than the black one, It's thicker, but the black one in my Zip hasn't leaked yet. Yours might be cracked.
Is it just crooked in the bore or warped when you have it out? They can fit mighty tight and go in crooked.The round plastic part is warped and uneven
I think I've got a package of OE Tillotson strainer cover gaskets.Yeah that last kit I bought for a Tillotson had a cork gasket for the inlet, I like it better than the black one, It's thicker, but the black one in my Zip hasn't leaked yet. Yours might be cracked.
