Time's Standing Stihl
Below me...
- 7:54 AM
- Apr 20, 2016
- Central Iowa
Poor girl isn't getting any attention from you. ....what do you mean?
Have you run the timing numbers on that saw yet. I would be more concerned with the machine work after I knew where the numbers were at. I have seen some of the China cylinders for the 660's that were way, way off from any stock numbers that I had to compare them to. Exhaust numbers were lousy and if you go dropping the cylinder check your clearance on the piston skirt on the exhaust for any free porting that may occur. Had that happen once as well. Not a deal breaker saw ran alright but not optimal.I wanna get it the best it can be right now then when I'm used to it I will try and port it to masterminds provided ms660 specs
she brought my son in and sat him down beside me and told me he is going to help me build my saw and he looked at me for a second and instantly went to staring at the dogPoor girl isn't getting any attention from you. ....
I have not ran any numbers yet I still haven't got a timing wheel lol i think my gf got me one for ChristmasHave you run the timing numbers on that saw yet. I would be more concerned with the machine work after I knew where the numbers were at. I have seen some of the China cylinders for the 660's that were way, way off from any stock numbers that I had to compare them to. Exhaust numbers were lousy and if you go dropping the cylinder check your clearance on the piston skirt on the exhaust for any free porting that may occur. Had that happen once as well. Not a deal breaker saw ran alright but not optimal.
Sent from my N9516 using Tapatalk
Everything is shutdown here in mid Mo. People sitting on level ground going nowhere. Luckily I took my wood truck to work today and made it home with no issues.How everyone doing getting a little icy here in Topeka
Roads weren't icy at all temp was 35 misty.Outside resembles a glazed donut from Dunkin.
I hope Kenneth and Chet get home safe.
School buses ran late and the last few kids went home around seven.
Deputy daughter reported I29 and hwy 36 were shut down a while.
Be patient. Put it together run it.I want to check all of the numbers but I just have no way at this time. I know. I suck. Lol
I made mine from a printable off a google search image glued it on a piece of 1/4" ply then used an old drill chuck off an old cordless drill to attach. Works great just wish I would have had a 1/2" drill chuck. Have to use the flywheel side of the crank on the big saws. Just have to be careful still works good though......I want to check all of the numbers but I just have no way at this time. I know. I suck. Lol
Nice, Mike.Evening fellas, shop stove is burning good, got the walnut prepped for mommas Christmas present, now on to rocking my Victoria to sleep. Freezing drizzle here... Gonna weld up this cross for my oldest.![]()
I would use Clydesdale shoes but I can't afford those....Nice, Mike.
