Douglas Ostrander
- 7:18 PM
- Dec 4, 2015
- Waukee Iowa next to I80
Spaded moved and then replanted 14 big trees today. Lots of driving back and forth.
It's name sake Booker Noe, was the head distiller at Jim beam distillery IIRC..I know some of you like whiskey. An American whiskey won World's Best this year. If you want some, be prepared to dig deep. Whiskey drinkers up:
http://www.foxnews.com/leisure/2016/10/18/american-whiskey-nabs-covered-best-in-world-title/
Some of us have known about it before the bourbon snobs figured it out..
Lol..
Meh...Must be some good stuff. Is it worth the $$$$? What a review this is. Makes me want to try it, although it would be a waste on me,,,,but still: http://modernthirst.com/2016/06/14/bookers-rye-review/
I am glad you showed those pictures,it reminded me I cut a standing dead walnut just a little bigger than that last spring.I was going to free hand a
I preferred ATF. Much more dramatic.The 'Driver dip' is not without risk. I managed to get enuff moisture in the 050 crankcase to short out the plug when I first tried to start it.
Aired it out by pulling it over twenty or so times before putting the plug back in.
No harm done but if it sat long enuf it would most certainly would have.
Remember the '70s when you had to dump a 16 oz bottle off water down the carb throat of an idling engine to cure 'run on'?
That was some bad fuel, I think evenMid '70s my HS buddy had an El Camino with 402 BB. Once a month 16 oz of water down each primary throat. Otherwise it would knock and run on.
