plcnut
Jesus is LORD
- 10:37 AM
- Feb 20, 2016
- Mansfield, Missouri
You got that right! These parts add up fast...Better make a bank run first.
I have 9 more valves to go yet in that main loop...
I have to make another parts run in the morning.
I have done maintenance on enough boiler systems to greatly appreciate proper valving. I will only need to use them once in my lifetime for it to be worth all the trouble and expense of getting it right.In the long run you will be happy you put in all the valves. You will want one at the end return line too. So the water doesn't flow backwards while making repairs. One way valve doesn't always work. Does Central Boiler still use the temperature bypass?
Evening everybody.
Boy it's cold and windy out there! I'm chilled to the bone.....
Got a bit done.... that sure does look like a dandy hay loading hole.....
Notice how out of level that bugger is...
It don't look too horrible as long as you don't open the door......
But then it looks pretty embarrassing.....
"Even with the trees"
Good afternoon.
I had my tree guy drop a good sized oak that was dying beside the house.![]()
Sent from my LE2117 using Tapatalk
Good afternoon y'all. My 200t is leaking bar oil. I experienced a broken brake handle last year that coincided with the oil leak. Must have dropped a piece of firewood on it or something. It looks like I pretty much have to disassemble the entire saw to get to the tank itself. Is this correct? I'm currently looking for a shop manual butthought I'd ask herein the meantime.
