moparnut88
12:44 PM
US
I think I saw something like that but it only went to 18” or 20” chain lengths.
hoskvarna
11:44 AM
Iowa
I made one for a buddy out of a piece of 1/2 in plywood
Cut a 3in piece off of a broken broom handle and screwed it one end then cut 2 more and put a bolt in and wing nut then cut a couple slots with the router so they would slide to tighten to hold chains
Sorry no pics
Sent from Hoskey hilltop
sawnami
12:44 PM
Springfield
FINALLY!!
Got spark on the old 1-10.
:aaaaa:
Must be a sparky kinda day, Steve.[emoji16]
The old Homelite pump fires on a prime shot. The tank had 1/4" of crud in it. Poured it full of HydroForce industrial degreaser. It cuts old hard grease like nothing that I've ever seen so I thought I'd try it in the fuel tank. Now the tank is perfectly clean inside.
Sent from my LE2117 using Tapatalk
JimBear
11:44 AM
IA
Had a tornado touchdown 8mi north of us 1/2 hr ago
Too dang close [emoji15]
Glad it didn’t swing thru & say hello. Hopefully it’s all moved thru your area now. It just terribly windy here now that the front has moved thru.
Semotony
11:44 AM
Glad to see her Inna good home! I gave $20 for it
Auction ZIP Zip code 63650 for a full mount Africa leopard, not enough? Lioness full mount. Starts 1 pm Sunday the 6th. I'll be there. No service at sight.
Want me to bid on either for you? Contact before 10:30 am and leave phone # what I can do there will get done for you
Fishnuts2
11:44 AM
SE MN
Well, it took two years to find an air filter housing, parts scrounged from 3 carburetors, clean the points, repair the starter pawls, getting that rotten recoil spring back in the housing, and fuel lines, but it runs finally. Thinking if any of you guys want to borrow it for a portable porting grinder, just let me know! It’s too loud for indoor use though. [emoji2958]
