Jetmd
4:42 PM
Smithville, MO..Born in Iowa by the grace of God
Shotput and discus for me, along with the fatman's 440 relay. I like Kenneth never could get the spin down,
luckily I did well flat footed. Loved the shotput. Our 440 relay team was made up of the discus and shotput
throwers and we actually did OK, at least we never finished last. Never won but that was just fine with us
stocky guys.
Workshop
4:42 PM
Nixa, Mo.
I was a sprinter, a hurdler. At the time, the intermediate hurdles was 330 yards. 3/4 of the track. Not sure if they even run this race anymore, at the high school level. I could run the 1/4 mile at 56.0. Intermediate hurdles, my best was 51.5. I had the advantage of being a left legged hurdler, which meant I could run at the left line of my lane and when I ran the hurdle I would come down in the middle of my lane instead of closer to the right side of the lane.
cobey
4:42 PM
Pittsburg, kansas
Well, if Amy of you ever see me run....
You better run the same direction because something SCARY is coming
After me... I don't run ... well maybe
Jog when someone rings the dinner bell :)
Workshop
4:42 PM
Nixa, Mo.
Between putting up a picket fence at my daughter's house yesterday and then installing an attic fan for her this afternoon, I actually got some time this morning to work on the project truck. It would run for a few minutes, then gradually flood itself out.
Found one of the TPS wires had been cut and then just twisted together and wrapped with blue masking tape. Soldered it back together, then marine shrink tube over that. Now it will stay running, but still has bugs in it. More sensor testing in line. Found 3 cracks in the passenger side exhaust manifold, so bought a new replacement to put in after while. Let it warm up real good and build coolant pressure and found a leak somewhere behind the water pump. A gasket gave out, so it's time to pull it down to the timing chain and replace all the gaskets. I'll probably pull the intake too and replace those gaskets as well. That will make it easier to check all the vacuum hoses and connections and all the wiring, too. This should be interesting, stay tuned. :)
Hedgerow
4:42 PM
When you're done, I got a weed eater you need to dissect Steve.. Lol.
Why do neighbors bring me dis functional junk?
I really don't like working on the stuff. I try to limit myself to saws.
67L36Driver
4:42 PM
Morning Kenneth!
Morning midlanders!
Belly up to Jack Horner's parts counter later. [emoji849]
