Hinerman
7:07 AM
NE OK
These mornings are nice; low to mid 60s, then the devil takes over and it's 90 degrees when I get off. The biggest difference in temperature I ever experienced was in Death Valley; 115 during the day, 60 at night.
sawnami
8:07 AM
Springfield
Good morning.
I got some new blades for the mower/rock crusher. [emoji846]
1/4" thick (1/16" thicker than the originals), 3" wide vs 2-1/2" for the originals, and a higher lift angle. Also fused with carbide. Might be fun to sharpen when the time comes.
Mowed with them yesterday and they seem to work great.
Lurch
7:07 AM
Long Lane, MO
When I was on the road. Started my day in Dillon CO. -8. Ended in Vegas, 88. My biggest swing.
Cat 525
7:07 AM
Central Kansas
110 acres down..
Bout 120 or so to go yet.
Moisture range 12-14%
average test weight 59
Our test weight here is 57-58. Shriveled pretty good! That heat couple weeks ago. How's the yield? Cut a hill 80 and uield was 54. Boys didn't fungicide and quite a bit of rust!
Hedgerow
7:07 AM
about 77 bu per acre average so far..
Should go up a tick after this last field.. It was running over 80..
The one behind my house will be lucky to go 65.. lol
TALLGUY
7:07 AM
VERMILLION SD
Good morning.
I just put a set of the G6 blades on my 52 inch gravely zero. Seems to mow well. The old blades were almost worn in two. The mower is new to me so will see how they perform.
Workshop
7:07 AM
Nixa, Mo.
Good morning.
Where did you get them? It'd be nice to have those for down at Hootin Holler.
sawnami
8:07 AM
Springfield
I got them through Sydenstricker John Deere's eBay store. Pick out your blades and put them on your watch list. In a few days they'll notify you of a reduced price to get you to pull the trigger.[emoji6]
Cat 525
7:07 AM
Central Kansas
Sounds good! That late freeze and then the heat hurt us! Nobody's nraggin. 60 bu gonna catch alot of it.
Hedgerow
7:07 AM
Two combines can sure make quick work of 40 acres..
Almost more than the semi’s can keep up with!
The yellow top combine is an older 7720 the neighbor bought and wanted to work the bugs out of it on a clean field. Ran great.
