sawnami
8:14 AM
Springfield
Now I might believe that! I even dropped some on a clean white napkin and no color change.
So it evaporated without leaving an oil spot? Not a good sign if so. At work we check for diesel-contaminated gas by putting a few drops on a piece of cardboard box and see if it leaves an oil spot when the gas evaporates.
Sent from my SM-T900 using Tapatalk
67L36Driver
7:14 AM
Building the 026 and MS260 came to a halt.
Farmertec muffler is 3mm short fore and aft. And two of the 4mm starter mount screw holes on the 026 are stripped.
Brake handle on the 026 is heat warped from running without the left side anchor/pivot.
Tree service saws. [emoji37]
7:14 AM
Looks like the coil was dragging too.
67L36Driver
7:14 AM
Yes it was. Main bearings were shot. Got to the point you couldn’t adjust the coil back far enuf. [emoji15]
Morning midlanders!
Stihl waiting on Farm Boss muffler. DHL handed it off to a ‘delivery service’ in St. Louis. WTF !!
Likely USPS who should have been used in the first place.
7:14 AM
teacherman
7:14 AM
NW Virginia
Good morning!
Busy busy week.
Looking forward to mini gtg at Kenneth’s tomorrow morning.
Got my fishing pole throw line setup together. 1 mm Dyneema spear fishing line, a 2.5 oz sinker, and a gigantimongous spinning reel from eBay
Yee haw hope it works!
Take care gentlemen
67L36Driver
7:14 AM
Whats a close tap drill size for 5 mm x .8?
Two of the 4mm starter screws need grow in size on the 026.
