- 10:46 AM
- Feb 10, 2016
- lincolnton nc
Yeah, I used a regular paint but I'm pretty set on not running this as it's coming out to darn nice. hahaFrom info I've read cylinders aren't really supposed to be painted on air cooled engines, they say it interferes with cooling. I don't think Hi Heat matters either. I guess if you don't plan on working it much it wont matter though. Good luck.
EDIT: I googled it and apparently if you use a good Hi Heat paint it won't affect the cooling much, but most regular paints will bubble off.
Thanks man! I want to hear it run as well, but I've seen what gas does to paint and that's what's keeping me from running it. hahaLooks incredible TJ! Not gonna lie, a little depressed we won’t hear it run but I understand.
What type of paint did you use?Thanks man! I want to hear it run as well, but I've seen what gas does to paint and that's what's keeping me from running it. haha
Yep. One piss rev is all that would be required. Dump the gas back out and shelf itI’d be at least firing that bish up
YessirYep. One piss rev is all that would be required. Dump the gas back out and shelf it
Thanks! Paint is Duplicolor primer, base, and clear. I'll be switching to V-max clear soon as it's a two part with a hardener. Handle gas and oil way better.What type of paint did you use?
Saw looks great as well. Very nice job
