Help with this?
DELETED (Struggle)
10:50 AM
iowa
Does the cs 2145 handle split in half. Guy dropped it off and the operator presence handle is locking out the trigger somehow.
I don't see any screws holding the two halves together.
Sent from somewhere
Motorhead
Cantre Member
11:50 AM
Tampa Fla.
That looks a lot like a 346 tank,the lock out comes out of the top of the handle,it clips in the trigger has a small rivet in the very front of it,tank does not split.
P.M.P.
Stiff Member
11:50 AM
Michigan
Check out the spring in the handle
DELETED (Struggle)
10:50 AM
iowa
I have seen tanks that have a roll pin that you can drive out but this tank only has a roll pin showing on one side? Do you still drive it out to remove the operator presence part? The top part of the trigger springs normally upward on its own. Something is clearly upset though in there.
Sent from somewhere
Motorhead
Cantre Member
11:50 AM
Tampa Fla.
There are two levers on both side of the operator presence button towards the rear of it,a small screw driver pushed between the handle and the lever will release it through the top of the handle.
DELETED (Struggle)
10:50 AM
iowa
^ I'll try this tomorrow thanks for the info!
Sent from somewhere
DELETED (Struggle)
10:50 AM
iowa
Fixed! The plastic push piece that goes over the end of the throttle rod fell off down into the trigger and was stopping the trigger from coming up. Customer took the saw apart partially to clean so he must have done that cleaning it.
Thanks for the info.
Sent from somewhere
