help with old aircompressor
smokey7
3:32 PM
Detroit
Got a old craftsman 9121541000 model aircompressor Its got senimental value and i need piston rings for it. All three are broken. 2 are 1.58mm x 56.54mm roughly the bore or simply its really close to 1.75" rings are about 1/16 oil ring is about 1/8" and has a bunch of holes. They are NLA afak help. Id really like this to run again. I think gpa would smile in the ground if i fixed it. I found a piston with rings for 66$ and well i think thats too much as it only needs rings. Help how do i fix it. Would it run with only comp rings and something inplace of the oil ring? Or maybe leave the oil ring broken? HELP ME PLEASE.
smokey7
3:32 PM
Detroit
Oh he is but all the rest of the piston and rod is mint. I will try the liklnk above. Thanks so much. Its probably only 150$ unit to begin with
merc_man
merc_man
3:32 PM
southern ontario
If something has sentimental meaning. Do what ever ya can to fix it. Even if that means buying over priced parts.
3:32 PM
Generally speaking you can find generic sized rings to fit just about anything if you look hard enough .I once installed Ford 2.5 liter HSC 4 cylinder rings in a friends 1937 Waukesha engine and they worked perfectly .
smokey7
3:32 PM
Detroit
I looked at thumper pocket bikes a d they seemed to share the same ring size. Hell i may be able to deck mt jug and run the piston even. Thanks so much guys. I may just order the correct piston kit even tho i called them and they said its nla. Maybe someone got one with something else nad and ill buy it for parts. I also got a hd special cambell housfield one tyat needs a nla piston too. Weird chit i tell ya
Basher
4:32 PM
Canada
If you need rings for any application these fellers likely have them, rings go by bore diameter and piston ring land thickness. Just determine your bore and ring thickness then look them up on this site below,
https://www.hastingspistonrings.com/
