Grease Monkey Garage
jacob j.
Only the weird
2:49 AM
Coastal Oregon
redline4
I'm huge in Japan
4:49 AM
Rosholt Wisconsin
Canadian farm boy
“Normal” people scare me.
5:49 AM
Ontario, Canada
That the throttle body Holley efi?
Someday I will have to repower our 429 F700…diesel is no go here
Holley Terminator x and x max are the mpfi systems. X max has transmission control
Holley Sniper efi is the throttle body system
Steve
Excellence!
4:49 AM
Bigmac
2:49 AM
Looks very nice Nathan! Do you have to port it differently to be used at a constant throttle for the street?
Thanks Steve, it’s a little different, but mainly it’s gearing, I soften the bottom end hit and increase the rev range, going to try a different pipe too. Mainly need to to not be wanting to come on the pipe too soon so it will lug. Excited to have a wider spacing for the gears so I can lower the overall gearing and make 1st gear be more manageable.
Yukon Stihl
2:49 AM
Great White North
Had some spare time do I knocked off a minor change that solves an expensive outcome. Took off the timing gear cover and installed the Killer Dowl Pin keeper.
Got a Fluidampr so it was time to install it too.
Had to tap the dowl pin in to be flush with the housing, so it was on the move.
4:49 AM
Yukon Stihl
2:49 AM
Great White North
We were without phone and internet service for 24 hours Territory wide.
Made for a quiet day so I was able to get the clutch on the Franken truck sorted.
The mounting bracket twists off the Dodge clutch cylinder so that helped. It had been modified for the Ford once already.
It was all made to replace with a stock Dodge one if ever required.
Moparmyway
Its just a saw
5:49 AM
In a meeting
IMG_2278.jpegIMG_2283.jpegIMG_2290.jpegIMG_2293.jpegI quit fiddley-diddlin around with the different assemblies for conversations to 4 wheel disks. Figuring out how to replace missing mounting pins or even something simple like replacing pads or rotors is impossible as the manufacturer would only “discuss” parts with distributors and the distributor gives you the manufacturers phone number ……. Talk about a circle-jerkyIMG_2276.jpeg
Switching out the rears next for Wilwoods 4 piston kit with emergency brake and their master cylinder and prop valve so everything is matched and designed to work perfectly as a system
