- 7:22 PM
- Jan 20, 2016
- NE OK
You need to fix that problem!!! Is it possible?I do everything in it that I do in my pickup, and more. Except go 85.![]()
60 feels like re-entering the earth’s atmosphere from space.You need to fix that problem!!! Is it possible?
The radial tires must of improved the ride.60 feels like re-entering the earth’s atmosphere from space.
Yes, but they're not balanced and the wheels aren't precision either, so still some shaky.The radial tires must of improved the ride.
I doI'd think a youtube celebrity would be willing to just drive through the vibration for his fans...
If you want to redneck balance them next time you’re bored. Break the beads and put 5-6 golf balls in each tire. I run 4 in my 11-24.5 steering tires and 3 in each dual.Yes, but they're not balanced and the wheels aren't precision either, so still some shaky.
Kinda hard with inner tubesIf you want to redneck balance them next time you’re bored. Break the beads and put 5-6 golf balls in each tire. I run 4 in my 11-24.5 steering tires and 3 in each dual.
My Mack dump truck with camel back suspension rides like an air ride truck.
Sorry assumed tubelessKinda hard with inner tubes![]()
The tires could be but I was too cheap the switch rimsSorry assumed tubeless
Hell Yeah !!!Got a bunch of wiring done. Sort of..
Need to get a buss bar to minimize the battery positive connections...
Wiring to the fuel pump is done, wires to the inside of the car for the fan relays and fuel pump relay done..
Engine cranks with the ignition switch.
View attachment 455297View attachment 455299View attachment 455300
