Fuel stabilizer
jakethesnake
I Am The Snake
7:42 AM
Here & Now
Assuming you mean that you put it in the gas? I started putting mix oil in all my cans because I don't trust the kids to not straight-gas my equipment. So far it doesn't seem to bother my utility vehicle or my push mower....the lawn tractor is diesel, but I add mix oil to it as well.
Yes in the gas
FergusonTO35
7:42 AM
Boonesborough, KY
A long time Ford tractor mechanic once told me that putting a cup of bar and chain oil in the fuel would help the valve guides. I'm sure 2 stroke oil would have the same effect and probably burn better.
FergusonTO35
7:42 AM
Boonesborough, KY
Honestly, the biggest problem ethanol causes me is black mold or whatever that discoloration is that builds up in the gas cap area, as shown here:
7:42 AM
I don't know if it's ethanol or what it is but my one Fergie TO 20 is giving me fits .It sits most of the time being a loader tractor and as such the carb plugs up and drives me nuts .II's a simple Marvell up draft but it needs rodded out again .If not it will starve out when you least expect it like right in the middle of a lift .What I'm doing right now it takes a loader as I'm not nearly as strong as an old timer as I was as a younger man .Time to turn a wrench ----or in this case a screw driver ----It was brand new in 1950 I was brand new in1948----
12:42 PM
I do not utilize fuel stabilizers, though I may just be lucky my local gas is rated E5.
I keep all my gas OPE topped off and I try to start them up every month or two.
So far it seems to keep fuel related troubles & issues at bay.
lehman live edge slab
Live Action
6:42 AM
Mn
Your same age as my dad roughly and I saw him trying to lift stuff and told him I have forks for my tractor right there. Told me he didn’t want to use my stuff and I had to chew him out because it’s for his use as much as mine when he’s over doing projects. I live in the house I grew up in and he built in the 70’s so he’s over all the time because he can’t sit in the apartment which I don’t want them doing anyway. Far as fuel stabilizers I used to use some but don’t much anymore unless it’s built into the oil. Almost all of them have a large amount of alcohol in them and your adding what your trying to avoid with e-free fuel.
edisto
7:42 AM
SC
The alcohol in fuel stabilizers is almost always isopropanol, which behaves differently from ethanol in fuel. Both are hygroscopic (they absorb water), but that interaction with water causes phase-separation with ethanol, and not with isopropanol.
