kielbasa
- 10:43 PM
- Jan 31, 2020
- Kewaskum, Wi
Hi guys, a novice local porter is going to hold my hand while I attempt my first saw.
I'll start with dialing the squish to ~.020". I won't be machining the head, just the cylinder base.
He mentioned 1 to 2 degrees on the exhaust, open the lowers as much as possible and take the intake up 10 degrees or so. And then do tonsils/ears.
All I want is a saw that has more nut than stock. I mentioned I lean on my saws and prefer low end power vs high rpm screamer that snuffs the chain as soon as I lean into it. He then mentioned possibly not even raising the exhaust then.
Do these numbers seem reasonable? I completely understand if nobody wants to divulge their recipes - am just looking for a little bit of guidance - Thanks for any info!
