(First Post) porting help
srcarr52
11:31 AM
Iowa City
As it stands now the numbers are, exhaust 101, intake 81 and transfers 121. It has a HD 12 carb. Unlimited coil.
What BB kit is this? I've never seen a 372BB cast with over 150 ex duration (105 opening) and you haven't ground on the port roof at all. So I think your numbers are a little suspect. I wouldn't run more intake duration than exhaust.
I can't tell by the pictures if you did, but when you cut the base remember to cut the skirt extension. It could be bottoming out on the case before the gasket surface touches.
Ronie
11:31 AM
NC
I'm not sure of the brand, white box? The numbers are right, I've had the wheel on there three times and got the same numbers. I've also checked the exhaust two different ways. The normal way setting up the wheel using a piston stop and starting at zero when the exhaust opens. Same number both ways. I cut around .017 off the base and cut the cylinder skirt also.
srcarr52
11:31 AM
Iowa City
Do you have a dial caliper? To get 101 opening on the exhaust with 0.020" squish the port roof should be 0.960" from the squish band.
Ronie
11:31 AM
NC
I have a caliper. I havn't pulled the cylinder off yet but will measure it as soon as I do. As soon as I finish my coffee I'm going to pull it off.
Ronie
11:31 AM
NC
My numbers could be wrong if I'm not doing the exhaust right. I'm taking the number the pointer is on right when I see the first bit of light.
Ronie
11:31 AM
NC
I pulled the cylinder off and the top of the piston is very black and the crankcase is wet. The whole problem maybe because it needed lean out. I can't really hear a saw four stroke when the rpm are up, I can only hear it when the tone is low. That maybe why all my saws end up around 13,000 rpm.
Ronie
11:31 AM
NC
gasket on the cylinder
Ronie
11:31 AM
NC
I measured it and I got .990 and the squish is .017
srcarr52
11:31 AM
Iowa City
That puts you at 152 duration, 104 opening, more inline with what I would expect. I normally expect 1 deg opening error between the mathematical way and reading the port opening on a wheel, make sure your not letting the port chamfer put too much error into your reading.
EvilRoySlade
What’s my line?
11:31 AM
Michigan
“You’re”, that time it mattered. :borra2:
Ronie
11:31 AM
NC
Ok, the pic is how I've been reading it.
srcarr52
11:31 AM
Iowa City
You might be reading some of the chamfer.
I've heard of peoples methods of removing error like putting a piece of paper in the port till it touches. The best method I've heard is taking two wheel readings with a 0.020" and a 0.010" feeler gauge in the port; then the real opening is the 0.010" reading minus the difference between the two.
So, I think you might need to add a bit more exhaust duration and try to flatten the entrance of at least the exhaust side transfers.
Also, you may want to unshroud the lowers. Mark the piston at BDC and then match the lowers to the piston shape.
Ronie
11:31 AM
NC
Thanks for the tip. I'll give the feeler gauges a try and see if I'm off.
HYPERSAWS
West coast cutter
8:31 AM
How many rpms are you looking for?
HYPERSAWS
West coast cutter
8:31 AM
I would go with scarr52 about the exhaust..
