First chainsaw!
tps3443
1:54 AM
Dunn NC
He wouldn't know what to think if he did that.
I have been watching those actually, before I bought the saw.
It will leak bar oil if it has oil in the tank. You need another saw to get the pinched bar out, A good ax, and some wedges. I reckon you read the oil threads. PPE including a bleed-out kit like Clottting agent, a Tourniiquet, An Israel combat bandage. Protect your hearing. You might think about a 16 inch bar and chain? Welcome and good luck to ya!
it hasn’t leaked anything. But I have not actually cut anything yet either. I have only ran it outside a couple times, I checked the blade was properly oiled. I adjusted the oiler just a smidge. Looks like it only has about 1/4 turn of total oiler rotation adjustment left or right. So I barely moved it to help oil the 20” bar. I saw a good oil mark on my concrete when holding the blade about 2” inches away and revving the saw. I saw a tiny bit of excess chain oil run off where the sprocket was, and wiped that up. It had been sitting inside all night, no bar oil leaks.
It shouldn’t leak right? I hope it doesn’t. That’s gonna drive me crazy. I like my stuff super clean and well kept.
trooney
Admitted Woodaholic
1:54 AM
The land of pleasant living
Dont worry about it, if it leaks you'll know it. Usually in the hotter weather but not always. I good thing to do is to crack the oil cap after using it to releive whatever pressure is in the tank.
Loony661
462’s 4-LIFE
12:54 AM
Winona County, MN
The more you spin the chain without having saw dust and chips under the cover to absorb it, the more it will “leak” onto the floor or shelf, or wherever it’s sitting. Typically if you cut with it, it won’t leak any residual oil from under the cover, as it’s being absorbed by the wood particles.
tps3443
1:54 AM
Dunn NC
That makes sense! I’m going to start cutting with it soon. I’m taking a week off work anyways, and once I get some more gear, and some files, I’ll get out to the lot and begin cutting.
Sloughfoot
10:54 PM
Norcal
You said blade.
hacskaroly
2100 Fanclub Member
10:54 PM
Northern Idaho, Ehh
Unfortunately all saws leak to some degree, however, when you are finished using it, take off the clutch cover, take off the bar and chain and give it a good wipe down. A lot of drippage comes from oil that is just sitting there and over time gravity pulls it down. After cleaning it, open the oil cap to relieve any pressure. Doing this will help prevent puddles. Where ever you store your saw, you might want some cardboard or a puppy pee-pad under it just to absorb oil that drops after you clean it and put it away. Cardboard and pads are cheap and easy to replace when needed.
EFSM
12:54 AM
Extreme southern IL
My advice?
As I told an older customer today when I sold him a trimmer, don't drive over it, and don't run straight gas in it. If you don't, it will last as long as you want to own it.
(I did sell him Red Armor oil ;))
tps3443
1:54 AM
Dunn NC
Okay thanks everyone just checking, I think I can get it sharper than it is now honestly, and this is brand new chain. I’m thinking I’ll just get a round file that is 3/16, and maintain the same angle the blade already has.
Sloughfoot
10:54 PM
Norcal
Flat file and depth gauge. You'll need both in short order. I like depth gauges that give you choices, like Westcoast Saw's.
tps3443
1:54 AM
Dunn NC
I picked up some files!! 😃 Still need a few more things.
Can I run a 0.325/0.50 chain on my current 20” bar? My current chain is 0.63. Not sure if the 0.50 is only for the lite bars? I’m picking up some extra chains next. Thanks everyone!
mrxlh
I stayed late and finished!
12:54 AM
Dat Boot
Will it fit? Yes, but it will be sloppy as all get out unless you run a tight chain, which isn’t recommended either. Early in a saw hoarders life bar gauge width is something you have to pick, as it keeps things much simpler. For my larger saws, I’m all 3/8 -.050 bars except for a 32” which is 3/8-.063 and a 36”-.404, smaller saws I’m .325-.050.
Loony661
462’s 4-LIFE
12:54 AM
Winona County, MN
Great! Don’t back-drag the file across the tooth. Lift up and reset each stroke pushing forward. It may seem slow at first, but with practice you’ll get faster at it. Your files will last 5 times longer at least, if you don’t back-drag them.
It’s important to keep the correct gauge chain with the correct gauge bar.
