Firewood Measuring Sticks
Sagebrush33
8:18 AM
Upstater
I suppose that you could mount some type of bracket there, that still let you quickly mount and remove the actual measuring rod
Simplest I have seen was just a metal rod with an 'L' bent into the end, that attached to the vertical section of the saw handle with radiator clamps: could pivot out of the way, if needed.
These are great Ideas. I thing a fold back method would need a spring tension with a back stop, to keep the marker from being bumped forward. Combine both, and methods quoted and you get one marker to put on multiple saws with mounting brackets. Easy on - easy off ...... like an oversized allen wrench. If I'm making any sense .........o_O
8:18 AM
I bought one of those magnet sticks a while back. I make sure it is between the spikes to lock it in so it doesn't slip down. I use that OR just a measure stick that I always have with me. Fiberglass rods precut to 16 inches for me. So I can fit into my stove.
Philbert
Chainsaw Enthusiast
7:18 AM
East Dakota
They are actually photos of special, environmental, measuring sticks: for assembling firewood back together into logs and trees.
Philbert
redoakneck
8:18 AM
Ohio326
Good catch, I thought something looked strange. If you look at the bar, the Stihl label is backwards also.
I don't know, I can not find a source for a left handed saw!!!
Is the camera reversing the image?
166
Habada
8:18 AM
Greenwich, NY
Jober is dead...I was actually able to find a company that made it for Husqvarna and they’re no longer in existence. I put a zip tie with a piece of solder shrink wrapped on my handle works mint when holding logs up with a machine. Other than that I use a stick and hold it in my mouth between cuts. I try to switch species for a different tastes. Lol.
Sent from my iPhone using Jasper
I see the must have saw tool there. Where'd ya find that?
Ontario Firewood Resource
8:18 AM
Toronto, Ontario, Canada
Lots of variation of the 'permanently' attached measuring rods. Many attach to the bar nut. The ones above appear to mount via the handle mounting screws. I suppose that you could mount some type of bracket there, that still let you quickly mount and remove the actual measuring rod?
@Ontario Firewood Resource 's rod maybe could be mounted with a wing nut for quick installation and removal?
I just think that the magnet sticks are so easy; work with any saw; on either side of the bar; require no modifications to the saw; etc. I have left them on when sectioning smaller diameter limb wood, and I have removed them after marking larger logs. Let's me keep both hands on the saw.
This a good idea if you have a quick disconnect so you can use the stihl nut tool instead of a wrench. When I use mine, it doesnt get it the way and it bends when navigating the chainsaw in and around your wood pile.
Philbert
