- 7:15 PM
- Jul 22, 2017
- San Antonio, TX
This popped up on FB MP for $600 then dropped to $450. I picked it up for $400. Have wanted one for quite some time now to fill the gap between the 044 and the 075.
S/N appears to be 123965831.
Anyway, it's a runner. Saw has seen some use, but tank looks good and the case doesn't have any damage. Handle and muffler cover appear to be the only non-OEM bits.
Now I have to figure out what to do. My normal course of action on a new-to-me saw is to install fuel line, impulse, fuel filter, air filter, compression test, lube clutch bearing, pull the flywheel and clean ignition bits, and rebuilt the carb. If compression is on the low side, it gets rings and prolly a BG delete while I'm at it. I'll probably do a muffler mod of sorts, too.
Once I've gone through it, I think I have a nearly new 28" Tsmura bar some some 3/8" chain for it.
What did I miss? Also, what's the deal with the big bore kits for these?
