old 040
- 7:07 AM
- Jan 18, 2016
- Buckeye State
Not all of it...I somehow lost the photo but the fuel line in the tank and the oil line in the tank were just goo.
I'm happy to report that my oil line repair works, almost too well.
This saw came equipped with a 1/4" pitch chain and sprocket nose bar, but the previous owner thought he'd run a 3/8LP drive sprocket. As you can see, the drive links on the chain had suffered as well.
Evidently it was run that way for quite a while with the chain loose enough to go around and slap the end of the bar near the sprocket quite badly.
They also tried to hold the muffler cover on by threading a 1/4-20 screw into the hole of the baffle which did not hold so I used a rivnut to provide a solid anchor.
That project is done for now.
Mark
I know this post is from July, but just wondering if you preset the oil pump. IIRC once the adjuster cap is removed the hex top of the pump should be turned in until lightly seated, then backed out about one turn. Then run the saw and see if it has slowed down the oil flow. If all's good then replace the adjuster cap so it's in the "halfway" point of adjustment so it can be slowed or set for more flow from the preset position.
