echo 8000...porting ideas?
jacob j.
Only the weird
11:47 PM
Coastal Oregon
How wide are the piston skirts? You may be limited by that in addition to the narrowly shaped exhaust port. Echos tend to be very conservative with port timing and duration. Most Japanese brands go for a wider torque band with peak power being developed at a lower RPM range.
spencerpaving
2:47 AM
central new york
It's a full circle piston...skirt width is not a issue...but locating pins are in such a area I can't widen upper trans very much at all...I could flip the piston and put some fingers in there....
Brush Ape
Direct Connection
1:47 AM
Metropolis, Il
Realistically. ..prob a 24" for firewood duty....but there is a evil voice in my head that says "all out race saw" cause echo sponsers and sends in a film crew for a few of our events
I like Echo's version of Timbersports. Hey SP, have you ever got a close look at Matt Marks' hotsaw he built?
Cut4fun
Redneck Chainsaw Repair
2:47 AM
Ohio
2nd page p+c shows side by side comparison.
lwn9186
1:47 AM
I just picked one up with a scored p/c. It has a HDA153A carb on it which looks real small. Will be looking for some parts if anyone has any laying around!
bikemike
1:47 AM
Cottage grove mn
stock ex port....wtf!
Sent from my SCH-I545 using Tapatalk
Stock exhaust port looks like a easy pipe fit
bikemike
1:47 AM
Cottage grove mn
Send me a pic of your carb looking down the bore from choke side. Might be a cheep fix
bikemike
1:47 AM
Cottage grove mn
That is a husky 136 carb. It was a accelerator pump carb. I made it for a echo 330T 360t drop in.
lwn9186
1:47 AM
I'm with you now.
