Dyno
Ronie
1:10 PM
NC
It's actually reversible, k095 on one side and d025 on the other. I adapted a clutch drum/hub for the driven shaft so to use a standard rim, making chain pitch changes easy, just pop off an e clip a la stihl.
Excellent ideas, thanks.
wcorey
1:10 PM
ma usa
When my sprockets came in I rearranged the chassis design some.
It saw a bit of action but the software end of things had unfortunately stalled with no current eta...
wcorey
1:10 PM
ma usa
Sensors, generic ones anyway, are dirt cheap. Hall effect sensors are like a buck or two, load cells maybe ten, Raspberry Pi microcomputer thirty.
Commercial software to run things, cheap not so much...
We "had a guy" in house here writing up stuff from scratch but unfortunately he sorta burned out on it before things got finalized. Was a long road...
Red97
1:10 PM
MI
Awesome! I can't wait to see some build pics.
Approaching 2,000pulls on the new system.
I'll try and help out any way I can.
Ronie
1:10 PM
NC
Thanks, I'm sure I'll have some questions for you. Parts are coming in and I'll start getting it together soon.
Ronie
1:10 PM
NC
Got started on it today and got the table pretty much done, the welds aren't pretty but it's stuck together. I checked the price of steel and it has doubled in price so I ended up using scrap metal.
Ronie
1:10 PM
NC
Not much done today but I did get one of the axle shafts turned down so that I could slide a clutch drum on it, I'll weld it on there later.
Ronie
1:10 PM
NC
I got the pump support done this afternoon and welded the clutch drum on, I thought about just letting the pump hang off the shaft but with my luck, the set screws would come lose and drop the pump on the floor. It will probable be Thursday before I can get back on it.
srcarr52
1:10 PM
Iowa City
View attachment 340950 View attachment 340951
Is that one of those china 10 tooth sprockets? I'd wrap a new chain around it and see how it fits, the ones I got where all but useless. The OD was too small and it would hammer drive links bad!
Ronie
1:10 PM
NC
It's a Chinese one, here's a couple of pics, does it look ok?
jacob j.
Only the weird
10:10 AM
Coastal Oregon
Ronie
1:10 PM
NC
@Red97 do you tune your saws on the dyno as you're running it or run it, change the tune and run it again? Also, if I tune a saw for the highest torque number will it be in tune?
Red97
1:10 PM
MI
I tune on the dyno. As the bar/chain/sprockets all add some load on the saw.
I just tune like I would if going to the wood pile. Make a few pulls and adjust from that.
Need to develop a running procedure for your setup that is easy to repeat from saw to saw and day to day.
