ABarrick
TacomaTRD98 on AS
- 11:36 AM
- Feb 19, 2016
- Newville, PA
Carb was new correct?Appreciate the input.
I really think it’s a fuel issue. I have to check the tank vent as well.
It idled beautifully until it got hot. No issues on the high side.
I’m still out a full turn on the H needle, even with the jet drilled and the saw set at 15500.
How sensitive are the adjustments? Does an 1/8 turn make a huge difference or is it negligible?
That's how my 260 acted with the HD34a (ms361) carb. Ran great cold, good idle, very snappy, good power. Make a few cuts and get it hot, then it would only idle for a few seconds then start to load up and die and/or have an off idle hesitation/bog. Not something I could tune out and find a happy medium hot vs cold. I assumed fuel pooling in intake but it idles fine with the 194 and nothing else was changed.
In my case, the HD was a parts bin carb I just put new diaphragms in. I wanted to try that particular carb as the Venturi is smaller and I thought it may be better suited to a 50cc saw. That model has an accelerator pump which I figured would help spool up. But, they are prone to problems and I ran out of patience with it so I shelved it til I find some more time to sort it out.
I have not been 100% satisfied with the overall manners of any of the 1121 saws I've swapped HD carbs onto but it really wakes them up in the cut so I keep going back down the rabbit hole.
