Duane PA 026
Duane(Pa)
It's the chain...
11:45 PM
Centre County
I’ll be checking many things Deeter. The house has been neglected and will be getting my undivided attention First.
Good call.
Everybody can see where this is going...Something to play with!
BTW thanks for giving us pretty much a whole saturday
:borra2:
11:45 PM
The plan is to slap a new WT194 carb on the saw and make a few cuts in the same log later today.
Ill be working on the HD14 all week.
Will be a fun saw to use with the 194 to cut wood and slap on the HD intake and turn it up forntge cant runs. True dual purpose. I like that.
Duane(Pa)
It's the chain...
11:45 PM
Centre County
QTLA :Laie_22mini:
ABarrick
TacomaTRD98 on AS
11:45 PM
Newville, PA
If you're planning to run the WT with a stock filter, the 044 carb studs will be too long iirc. And you'll have to remove the add-on choke lever from the master control shaft each time you swap setups. Longer studs may work fine with velocity stack and 194 combo but you'll lose a choke when using the WT carb.
I like the build doc. Hoping this saw finds its way to chambersburg in June.
