chy_farm
- 8:36 AM
- Jul 3, 2017
- Yokohama, JAPAN
The expansion chambers (pipes) sound really good. Nice build.
Thank you gents for nice comments and welcome, glad you like them.Saw looks and sounds great! Welcome to OPE!
Hello Ajschainsaws, yep I started it early last year so it took me nearly one year. Gas welding to this thin steel sheet was my first try, so it was really a try-and-error to me, lol.Great build Chy, you've put some thought and time into this build
Welcome to the forum
So what I call for this part 'Exhaust Converter' was the first point I payed some of my thoughts.------
One of the tricky parts was that Echo used only one type of cylinder for her, and this cylinder has a exhaust port a little slanted to one side. So when they are placed in opposed positions each of their exhaust ports goes the other way. This required me to make each of their exhaust flanges in different shapes.-----
Thanks Deets, here posted new ones.Damn, we need more pics!
You are producing some very nice work there chy well doneThanks Deets, here posted new ones.
She needed a new front cover, since her newly applied under cover has some 30mm more in height. First worked with a paper copy ;
At first I thought the cover looks nice with the same design for the air vent holes, but changed my mind to get more holes for better ventilation ;
This genuine front cover had a crack on a bolt hole at the bottom left ;
This also gave me a reason to remake it.
Chy
Good afternoon Todd, having a nicest Saturday afternoon there?!You are producing some very nice work there chy well done
Hello Jake nice to see your Echo in your memory, really we should hate thief! Yes not very fast as Dolmar and Jonsered, instead most of them are hard-working and patient workers for a farmer like me. Not so new as yours is but I have one close to it, and she is a bit older, lol ;I use to own a 440evl before a thief wanted it more than me.
great saw though not the fastest but it was rock solid reliable like all echo products.
Hello Dan, thank you for nice comment and welcome, appreciate it very much. You seem to have a lot of professional skills for making pipes Dan, glad if you could show me here some links to your nicest works.
Chy
It's all part of the learning curve stick with it my friendGood afternoon Todd, having a nicest Saturday afternoon there?!
Thanks, but I should make calculation again for her, since the transport angles I put for these pipes were a little too big. I found it several days ago,,,,
Exactly Dan, funny but I was really believing that you are the master of pipe making. Now wish to see some artistic works of Brett, and learn something from them!I wish that were true. I was trying to figure out why you thought that. Then I remembered my avatar. It's a picture of me standing next to one of Brett's @spencerpaving saws.
Your work is inspiring Chy! It shows what we all can do with an open mind and some ingenuity.
Thank you for joining us!
Dan
Yep Todd, that's a part of our enjoyment! Thanks.It's all part of the learning curve stick with it my friend
Thanks it's an impressive information.
Chy
