Dolmar 7910 rebuild. Need some help
t4driller
Daddy Day Care
10:53 PM
Southwest pa
Hmm. Can't upload a video. Never tried to before and I don't use YouTube.
Sent from my SM-G925V using Tapatalk
t4driller
Daddy Day Care
10:53 PM
Southwest pa
Compression is 185 right now. Piston and cylinder look good. Gonna try and get a tank or 2 threw it then take it back apart and get some timing numbers and open it up a bit.
t4driller
Daddy Day Care
10:53 PM
Southwest pa
I got a couple tanks threw it finally. Compression ended up at about 190/195 . Im pretty happy with the way itd running in stock form pretty much, but i want more. So I took it back apart to get some timing numbers and open it up a little. I came up with
Ex. 106
Primary. 133
Secondary 137
In. 80.5
After reading a couple of threads here it seems like they benefit from raising the exhaust and transfers. So I plan on widening and raising exhaust, arising the transfers, widening the intake, muffler mod, and timing advance. Any advice is greatly appreciated. Thanks
t4driller
Daddy Day Care
10:53 PM
Southwest pa
10:53 PM
Don't raise the transfers much. These like 28° blowdown.
102 130, maybe 104 132. Don't lower your intake more
Miller Mod Saws
Chainsaw Masseuse
9:53 PM
Ravenwood,MO
Ex. 106
Primary. 133
Secondary 137
In. 80.5
What size of bar you gonna run and how heavy of a hand do you like to use?
t4driller
Daddy Day Care
10:53 PM
Southwest pa
I was planning on 102. 130. I'm gonna take my time and go slow. Take a little off and check it.
Miller Mod Saws
Chainsaw Masseuse
9:53 PM
Ravenwood,MO
Those numbers will work great. 2 details for ya that I think make a difference. Look at your entry angle of your transfers. Both the mains and secondaries are relatively flat. Try to maintain that and the square port shape. But mainly the entry angle.
Miller Mod Saws
Chainsaw Masseuse
9:53 PM
Ravenwood,MO
Left to right. Work on lower trans wall a little bit. Square it up kinda like my line and blend it down in.
Thin the bottom of the trans divider. Kind of point it and then blend it up into the tunnel just a little ways.
t4driller
Daddy Day Care
10:53 PM
Southwest pa
Gasket match and blend the right side. View attachment 19623
Thank you for the info. [emoji2] I spent some time laying out the ports and just looking at what I want to do. On the lower transfers I have it drawn out
almost identical to what you have there. I've learned from doing 372/365s that there's some good gains from nipping the corners and smoothing out the lower transfers.
Do I have to worry about the ring end gap coming down into the intake port if I widen and square off the intake? It looks like it stops above the port enough not to worry about it. I need to take the fuel tank and carb box off to be able to see in there a little better.
t4driller
Daddy Day Care
10:53 PM
Southwest pa
Finally got some time to do some grinding. I have everything roughed in right now. Intake got widened and raised just a tad. Case matched lower transfers. Raised exhaust and widened. Raised transfers. Timing numbers are
In. 80.5
Ex. 100
Trans 128 / 131
Still have to put bevels on. Numbers should go to ex 99. Trans 127/130.
t4driller
Daddy Day Care
10:53 PM
Southwest pa
I'm about ready to put this thing back together. I'm waiting on a new piston ring. The oem one I got had an end gap of .023 when I originally put it together. Yes I know it was way to much but new I'd be taking it back apart to port. I accidentally ordered 52mm by 1.5 mm. I checked that ring in it and the end gap was .004. Hopefully the one I'm getting is the same. Lastnight I gutted the muffler and opened it up. For the timing now.... I plan on advancing the timing a little. I also have a am 272 coil. Is it worth it to put that coil on or think I'll be ok just advancing the oem one? Thanks can't wait to put this thing in wood!!
Miller Mod Saws
Chainsaw Masseuse
9:53 PM
Ravenwood,MO
IMO for a work saw. The 7900/6400 anything with the 13500 it's not nessisary as they still tune pretty easy. The 12800 coils can be tuned just fine to cut wood but if the saws running good they can be running right on that rev limiter. And can be harder to tune. So do u need it. Absolutely not. Is it nice on the 12800 limited saws. Yes. Yes it is!
t4driller
Daddy Day Care
10:53 PM
Southwest pa
I'll see how it does with the oem coil. To use the aftermarket coil I think I read somewhere that you need to advance the saw 35 degrees. I'm having a hard time with the search locating exactly what needs to be done. Also the coil wire doesn't reach very good. Could I take the lead out of the oem and use in the am coil. What is the am coil limited to? Thanks
Miller Mod Saws
Chainsaw Masseuse
9:53 PM
Ravenwood,MO
http://opeforum.com/threads/7900-coil-swap.965/
Try this
