Lightning Performance
- 9:28 AM
- Jan 26, 2016
- East of Philly
Wow Kenny should have known you would be a Shandy guy!
Here's the Kicker.Wow Kenny should have known you would be a Shandy guy!
Or for someone that fuggs up their Zama a week before the buildoff...I guess!I’m happy with a bored out and worked over zama on my ported 7900. With some love the zama is a good carb on a worksaw. Most of the quirks are easy to fix. No need to buy a new carb for a ported 7900 if you or your porter knows how to work over the carbs. The hd12 is just an option for those who don’t know how to mod the carbs who just want a plug and play carb that works I guess.
No new nuffin.I’m happy with a bored out and worked over zama on my ported 7900. With some love the zama is a good carb on a worksaw. Most of the quirks are easy to fix. No need to buy a new carb for a ported 7900 if you or your porter knows how to work over the carbs.
No need to work over the carb if he knows how to port the sawI’m happy with a bored out and worked over zama on my ported 7900. With some love the zama is a good carb on a worksaw. Most of the quirks are easy to fix. No need to buy a new carb for a ported 7900 if you or your porter knows how to work over the carbs. The hd12 is just an option for those who don’t know how to mod the carb (or don’t want to) and just want a plug/play carb that works I guess.
AgreedNo need to work over the carb if he knows how to port the saw
He is trying to tell you that proper case and intake timing negates the need to dick with the carb on 90% of the saws ever made. It's just a fact not really news. Kevin learns in months what takes others sometimes years to grasp. It see his point most times.You saw a loss in hp with a bored out carb?
Didn’t say that. I just thin the shaftsYou saw a loss in hp with a bored out carb?
I swapped carbs back and forth with sondre’s 7310 with the one on my 7900 just to see if it liked it. Seemed to work good. Bout 5 % or so gain in wood on a already strong unit. Seems like drilling isn’t always necessity with all the variables in porting and elevation. Especially with the smaller 73 which doesn’t eat as much gas as a 79. Restriction seems to just be the venturi size which makes sense since it’s rather small for a 80cc saw. Thinning shafts alone makes a difference since it kinda does the same thing.Didn’t say that. I just thin the shafts
Usually lose some dawg-ability with the bigger carb though. It’ll cut faster straight down, sure.I swapped carbs back and forth with sondre’s 7310 with the one on my 7900 just to see if it liked it. Seemed to work good. Bout 5 % or so gain in wood on a already strong unit. Seems like drilling isn’t always necessity with all the variables in porting and elevation. Especially with the smaller 73 which doesn’t eat as much gas as a 79. Restriction seems to just be the venturi size which makes sense since it’s rather small for a 80cc saw. Thinning shafts alone makes a difference since it kinda does the same thing.
Be interesting to see at what point the venturi size would cause a torque loss. Probably a tipping point somewhere? Good for a dyno test, it wouldn’t lie.Usually lose some dawg-ability with the bigger carb though. It’ll cut faster straight down, sure.
It’s not really a torque loss, though that’s what we all call it. The torque goes up with the horsepower. But the curve is probably narrower. It’s just less forgiving.Be interesting to see at what point the venturi size would cause a torque loss. Probably a tipping point somewhere? Good for a dyno test, it wouldn’t lie.
Cool, makes sense. I guess we could see that curve change on the dyno sheet? Give some idea of what you felt in the wood and eliminate the variables.It’s not really a torque loss, though that’s what we all call it. The torque goes up with the horsepower. But the curve is probably narrower. It’s just less forgiving.
On outboard motors you give away the dog and the pink slip.Usually lose some dawg-ability with the bigger carb though. It’ll cut faster straight down, sure.
ZacklyIt’s not really a torque loss, though that’s what we all call it. The torque goes up with the horsepower. But the curve is probably narrower. It’s just less forgiving.
Kenny's been drinking since like 5pm.Wow Kenneth. Bouncing all over the place tonight I see. I thought this was a Dolmar saw thread.
