Does Stihl square ground suck?
12:39 AM
I have some loops on my 91dl bar. It sharpens quick but it's Oregon chain. I did file a loop of skip Stihl 110 dl yesterday a few times while I was milling. I hit the rakers once and shouldn't have. It was violent and had to try to keep the 394 from stalling in the cut.
12:39 AM
You're just slow[emoji12] skip is 1/3 less cutters than full comp. I haven't counted a semi to see.
The first loop of skip I've ever owned came yesterday on the 7310 from Guido. I ran it through the grinder once for the gullets and once to sharpen it. I noodles and bucked with it for an hour til it started raining. Noticeably quicker to sharpen and did a great job noodling
12:39 AM
I may try to test it later. I have ash that is about 20" wide. I don't think semi is that far behind full comp.
12:39 AM
I would really like to see the results of your tests, cause in 19" Red Oak, full comp was about 2 seconds faster for me (RSL compared to RSLH).
12:39 AM
It will all be filed chains. I'll try to get a semi skip touched up. I cut a rock with it the other day.
Might not be the same bar length. I can't find a single full comp 91dl. I may be able to do it with 110dl with a lot of extra sticking out.
KiwiBro (deleted)
12:39 AM
New Zealand
Someone here is selling 100' rolls of RSL for NZ$550 (about US$390). Am very tempted but:
  • never square filed before
  • don't see many super clean trees (once I have felled them, they are skud ;-)
Should I bite the bullet and have a go? Worst case I give up and grind them to a round ground chisel (I know, I know, you don't need to say it).
Are the RSL cutters the same length as RS?
junkman
Crush it
9:39 PM
pacific northwest
cutters are not the same off the roll ,but can both be made round or square ,i think the square ones may be a little taller i have over the round .
12:39 AM
I thought the RS & RSL were the same cutter, just with a different grind, but I could be wrong!
PS I like square!
Cracker Boy
Fl cracker
12:39 AM
Florida
No pro here but i like the rslh alot then when it dulls i just round file it and it works for me and yes the cutters are a little bigger i have found i have a hard time square filing plus stihl dont make rs in half skip and 1 square file is 12 to 15 bucks and dozen round files is 12 15 bucks its no brainer for me
