Hundred Acre Wood
Full-time Slacker
- 11:50 PM
- Dec 11, 2022
- On the hill
Too much diesel tech, lol. For proper scavenging in a two-stroke, you don't want mixing of the spent gases and the fresh charge. You want the fresh charge to blow in under the escaping exhaust and loop up & around toward the combustion chamber. The swirl you are talking about can be helpful up near the combustion chamber after the ports are closed. This is why it is important to have a tight squish band clearance to push the charge into the chamber closer to the spark plug.
There's also a tradeoff to be had. Turbulent air is better for dispersing the charge, but it's worse for moving the spent charge out.
So you have to balance turbulent air for maximizing combustion with laminar flow for maximizing exhaust. That's a tricky optimization.
